I’ve made this little tool to change panels’ colours based on random colour input. However, the preview is limited to the amount of panels, and the panels either have to be placed, named and referenced manually or manually placed within a group, what limits preview capabilities.
I, unfortunately, can’t use any external plugins in my workflow, so I’m restricted to what ships with Grasshopper.
Maybe there’s a better method or even a built-in one you know of? Thanks in advance.
A while ago I used this list of easily distinguishable colors. I added black and white so I ended up with 22 colors which is enough for most things I do.
No. They are colour palettes. Used for comparing colours or ensuring colour consistency in the traditional sense. In the digital era, they are colour preselections that ensure colours within a colour space or match print colour to screen colour. Just generally, they are a user-defined selection of colours.
Yeah, but a legend explains what colours are supposed to mean, or gives names to colours. I am speaking here of terminology.
A swatch would be like going into the colour picker an picking five colours that you like and saving them to a colour library. The swatch component would then give you access to those five colours and only those five colours in a drop down, depending on the colour library the swatch is displaying. At least this is what a swatch is in the Adobe interpretation.
Since I need a list of distinguishable colours quite often, I made a user object (just a list of strings) based on your post. Thanks for the reference.
I’m trying to not use AI for any of my projects, hence the reason I reached out to the forum. I wondered if anyone had a similar problem and came up with a proper solution.
I don’t. But at least there’s a chance (whereas there would have been none had I used AI directly ). It’s also a free chance to help someone else out in the future.
Well, if you hadn’t posted, no one would have used AI because of your post. By posting, you’ve actually prompted me and potentially many others to use AI.
If your goal is to discourage people from using AI, then the most rational choice would have been not to post at all.
But you still needed help and posted any ways. Kind of hypocritical, don’t you think?
What are you even on about man? People aren’t allowed to ask grasshopper questions on the McNeel Forums because it promotes AI? Is there a gas leak in your room or something?
