I have a .NET plugin (IsDotNETPlugIn = 1) that was designed for Rhino 7. It is registered under:
HKEY_LOCAL_MACHINE\SOFTWARE\McNeel\Rhinoceros\7.0\Plug-Ins\{xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx}
with LoadMode = 2.
There is no corresponding entry under the 8.0\Plug-Ins\ path. However, Rhino 8 still picks it up and loads it on every startup, which causes problems.
I want to keep using this plugin in Rhino 7, but prevent Rhino 8 from loading it.
What I’ve tried
Created a key under
HKLM\...\Rhinoceros\8.0\Plug-Ins\with the same GUID and setEnabled = 0,LoadMode = 0, andFileNamepointing to a non-existent path — none of these prevented Rhino 8 from loading the plugin. -
Disabling in PlugInManager does not persist across restarts.
Renaming the
.rhpfile works, but also breaks Rhino 7.
Is there a supported way to block a specific plugin from loading in Rhino 8 while keeping it functional in Rhino 7?
