How to place an existing curve tang. to 2 circles with fixed positions
Hi, the curve(s) an existing profile of a chair leg, the 2 circles are the fixed position of 2 clamps on the cnc rails. I can easily position one side of the profile tangent to one circle and rotate it via that circle’s center point and if the tangent snap would float on the line I would be done. So there must be another easy way. Thanks in advance…r.
I now see that I worded that incorrectly, its the reference point in the rotation that I was hoping would float until the tangent snap for the curve was activated. Since it doesn t want to do that for me I do need another way. Again thanks in advance…r
Maybe a picture of your situation can give as an example. Thanks,Mark
Is this what you want; one end of the profile curve is tangent to a circle, and the profile curve is tangent to a second circle? TanDC01.3dm (39.3 KB)
Steps:
  1. Create the two circles with points at the center of each circle
  2. Create the profile curve with one end tangent to one circle.
  3. Offset the profile curve by the radius of the second circle.
  4. Sweep an arc with center at center of first circle from the center of the second circle to the offset profile curve.
  5. Rotate the profile about the center of the of the first circle, first reference point is the intersection of the arc and the offset curve, second reference point is the center of the second circle.
nice one
Hi, thanks for the help, hopefully the pic adds clarity to the question…r.
Hope you figured it out . Looks like you could have rotated the object around center of right circle until it intersected left circle. Or perhaps object and right circle rotated around right circle (center) then intersect to left circle edge. Hmmm
oh yes that was the first thing I tried, but where do i put the cursor for the second reference point? So far nothing has popped up saying for tangency to that obj over there snap here, then rotate.
Ok, could you run an arc from right center to left center and then intersect object so to find intersect on object? Then do same operation as above?
Nope
GOT IT…r.
Instead of nope, i’d try it
@rjk The added circle does exactly the same thing as the arc I used in my post above.
I see that David. Wasn’t paying attention
Can you see how surface is interacting with cplane. Sorry ,this question was resolved about this picture and not related to this thead. — Mark
