I am trying to learn rhinocommon API.How can I perform UnrollSrfUV in rhino common?
BTW, I’d like to keep the original UV structure.
Assigned to Rhino Developer category.
thanks Dale. I can perform unroll but how to keep the original UV map?Is there any unroll options?
No,I tried several time,it cannot maintain the UV structure
Hi @Slone,
Can you provide a 3dm file that contains a surface you are trying to unroll and main UV?
Thanks,
– Dale
I should add that RhinoCommon doesn’t provided a UnrollSrfUV
function. So you may end up having to script the command.
– Dale
