@dale, thanks. It seems that OpenFileDialog.DefaultExt serves a different purpose than i expected. So i was able to use FilterIndex instead in the example function below.
import System
import os
def OpenFileNameEx(title=None, filter=None, folder=None, filename=None, filter_index=None):
ofd = System.Windows.Forms.OpenFileDialog()
if title != None:
if isinstance(title, str): ofd.Title = title
if filter != None:
if isinstance(title, str): ofd.Filter = filter
if folder != None:
if os.path.isdir(folder): ofd.InitialDirectory = folder
if filename != None:
if isinstance(filename, str): ofd.FileName = filename
if filter_index != None:
if isinstance(filter_index, int): ofd.FilterIndex = filter_index
if ofd.ShowDialog() == System.Windows.Forms.DialogResult.OK:
return ofd.FileName
