Using VBScript, how do I pass the String id of an array to methods that accept only String ids?
For example:
Option Explicit
Call Main()
Sub Main()
' Get object to be split
Dim arrBlock : arrBlock = Rhino.ObjectsByName("Block", True)
Dim blockToSplit
Dim s
For Each s In arrBlock
MsgBox "Object to split: " + s
blockToSplit = s
Next
' Get objects to split with
Dim arrPlane : arrPlane = Rhino.ObjectsByName("Plane", True)
For Each s In arrPlane
MsgBox "Object to cut with: " + s
Next
Call Rhino.SplitBrep(blockToSplit, arrPlane) ' <--- FAILS
End Sub
SplitBrep
requires String
s as input and arrPlane
is an array. How can I get the ID of the array arrPlane
to pass to SplitBrep
