How to output the results from Vray lighting analysis
I tried using the lighting analysis component of Vray in Grasshopper and rendered some images according to Chaos’s help document. I now need the numbers on these images. Is it possible to directly output these data in text or JSON format in Grasshopper during or after rendering? In the future, I want to use this data for analysis and optimize the existing lighting layout
there is no way to export the numbers, as they are baked in the image. One chance would be to scan the pixels and map their value against the color scale. This requires a little bit of scripting, but it is relatively simple.
Maybe you are right, there is no way to export these numbers :smiling_face_with_tear:
