can someone please help, I need to orient the “Radiator Curve” to points on the divided curve, so that the concave side of the large radius in the profile curve shows to outside.
Thank you, almost percect.
The insert point of the profile curve should be different, so that the 3 small radii meet as shown in the screenshot.
I think I had that correct in the initial version and can myself now.
Thank you again.
Thanks, I have already solved it by cutting the original rhino curve.
Also I have offsetted the orientation curve, as the profile shall not be proud from the original one.
And I have changed the end points of the profile, so that the large radius shows outside with it’s concave side.
