You can see a circle that is non planar and subdivided into several segments. I would like to “scale” the circle but I need the start and end points of each segment onto specfic axis, that i draw with the black arrows. The green curves gives an example, what I am looking for.
Unfortunately it is not what I need. The red points at my curve are start and end points from the individual segments. I need the start and points of the offsetted Segments in the direction of my drawn arrows. You can see that at the green curve and green offsetted start end points (example).
Hi, first of all thank you, but I can not find the correct Connection wire between the “startend” component.
Moreover I can not find the Setup for the Offset/Scale distance
Thanks a lot!!!
I can not find the sift Indices component in the latest Version of pufferfish. Can you replace this component with a current one and upload the definiton again please?
Thank you! But the result is not exactly like the original curve. In the attatched picture you can see, that the left curve (original) has a 3d-bending. The blue curve (new) is a straight Connection between the two points.
When I look from the top view at your cirves, I could figure out that they are not drawing a “perfect” circle. I am trying to continue with your definition, but I know that I have not enough knowledge to handle it. So when you have a little bit more time to fix it, I would be very thankful!
Hello again,
I continued with your definition and modified the original curve from the beginning. I tried for hours to find the error, but I do not know why the result is not correct. The original curve changed the amount of segments. The mayor looking is still the same, so do not worry about. Can you have a look again, please?
Here is the cluster with the internalised data
Thank you!!!
