I’m trying to move a void around the created mesh that will update the edges, vertices and faces when the void is moved. Much like using the evaluate surface component. See the image below what void I want to be moved:
Grasshopper script: Move_Void_Around_Mesh_Surface.gh (17.0 KB)
This is a exmaple script I quickly made to give you a idea of what I want to achieve: Example Script.gh (8.7 KB)
