I have four surfaces. I want to move them to the second layer.
how to do it using Grasshopper ?
I can select all the surfaces, but I can’t move them to “Слой 02”
грасхопер_иной_слой.gh (6.0 KB)
переместитель.3dm (178.9 KB)
This is not done is Grassopper, as far as I know. Layer property is defined in Rhino model space. Right click the layer with the objects selected and chose “Change object layer”…
If you’re using Rhino 8, you can use the new components under the “Rhino” tab to achieve this. See the image/definition below.
