Hi everyone,
I’m trying to improve my modelling skills and got stuck trying to solve the following problem:
Using VR and Gravity Sketch I built the left volume and would like to construct this in Rhino (but actually symmetrical)
I somewhat managed to model these curves but couldn’t find out how to proceed further. Is there maybe a better way to model this and/or similar shapes?
Would greatly appreciate any help!!! Screenshot 2024-07-22 at 23.38.54|690x497
you can copy your curves 2x and split them in different places to make the two intersecting forms,(side to side, then again but up and down) then pipe trim and blend the edges to get this-
Yes, thank you, this would be the optimal worksflow to continue! I have a Rhino 7 license and wasn’t able to open your file and retrace the process, how would I go about creating the overbuilt surfaces? Sweep probably? Would you mind converting to Rhino 7?
I used loft to find the form and then extended the surfaces to intersect each other. Split both then , joined and filleted the edge.—Mark volume_build.3dm (514.6 KB)
