How to model this building in grasshopper?
Hi, I’m fairly new to Grasshopper and I’m having trouble figuring out how to model this building in Grasshopper so I can parameterize it. I’m not sure where to start. Can you help me? I’d really appreciate it!
What is being parameterized? Ideally it would be a hybrid workflow using blocks. What is the final output?
Take away the outside pieces and you’re left with some relatively simple geometry. Those 4 major horizontal square sections you can sweep or pipe curves. Then divide those curves to get the points through which the vertical arcs must run.
I would start with those horizontal square sections and work from there.
Plus the additional square section at the bottom for the ends of the arcs.
See if this helps you.
model.gh (33.1 KB)
Thank you so much!, this helps me a lot, I will study the process!
