How to model a smooth heart-shaped border with sharp points?
I am trying to model a small raised heart-shaped border for 3D printing in Rhino 8. It is about 30 × 35 × 6 mm.
I want the surface to look soft, rounded and smooth, similar to a wax seal. However, the two V-shaped points shown by the arrows must remain sharp. The heart is also intentionally asymmetric, and its height and cross-section change around the border.
My current model was created from multiple cross-sections and two Sweep2 surfaces. Visible ridges appear where the surfaces meet, and they can also be seen on the printed part.
I do not mind rebuilding it or using a different modeling method. So far I have tried:
  • A closed Sweep2, but it self-intersects.
  • BlendSrf, but it creates an unwanted bulge.
  • NetworkSrf, but it creates more visible transition marks.
  • QuadRemesh/SubD, but I lose the precise inner and outer edges.
What modeling method or surface layout would you recommend for achieving a smooth result while keeping the intentional sharp points and accurate border curves?
I would prefer NURBS, but I am open to other Rhino workflows if the final model is clean and suitable for Boolean operations and 3D printing.
I have attached the 3DM file.
Thank you very much for taking the time to look at it.
file1.3dm (2.3 MB)
tried inflate curve? i think its in the wip
Same thing.
