@clement, @dale, @pascal, @brian, @nathanletwory, @Helvetosaur,
I create an Eto SemiModalForm
using:
args = TrimMeshArgs()
dlg = TrimMeshDialog(args)
result = UI.EtoExtensions.ShowSemiModal(dlg, RhinoDoc.ActiveDoc, UI.RhinoEtoApp.MainWindow)
dlg.BringToFront()
Inside the TrimMeshDialog
I make a call to an external procedure that trims a mesh:
# Trim button click handler.
def OnTrimButtonClick(self, sender, e):
trim_mesh(simple_trim, make_hole, make_trench)
I would like to minimize the Eto form before calling the trim_mesh procedure so that the Rhino window is clear of obstructions for selecting the area to be trimmed. So I want something like this:
self.form.Window.Minimize()
self.form.Window.Maximize()
I have done this with .NET windows but I am failing here. The error I am getting is:
Message: 'TrimMeshDialog' object has no attribute 'form'
but I have not figured out what to use instead of self.form
Any help on this would be greatly appreciated.
Regards,
Terry.
