I want to merge multiple planes that are composed of rectangles and then remove the extra lines.
Please see the diagram below:
I have thought another method to solve my previour question.
My dear friends, is there any good way to fulfill my requirements?
I haven’t deeply checked, but it seems that, IF the hexagon are kept regular (all sides same lenght), there will be 3 different spacing distances, not 2.
If you want just 2 different spacings then maybe you need to change the pattern or to deform the hexagons…
Thank you for your good idea.
If only using the Boundary Surfaces and Solid Uniform, I have solved the above question.
Thank this forum again.
