Hello guys, I have a big problem that has no idea how to solve. From the capture, you can see I already finished the basic shape for my skyscraper and prepared to loft them. However, the shape is bad because the starting points of these curves are different. Is there a way to change these starting points of curves to be the same?
problem.gh (288.0 KB)
Hi @YiXin_Mao
One way is to use the Align Curve Seams
component with the Seam
parameter set to 1.
possible solution.gh (293.6 KB)
HTH, Jakob
Thanks! that fixes some problems. However, the shape is still not what I want to have and I am not allowed to use more plug-ins for that thing. What I want to have is a very nice and ordered shape.
Hi @YiXin_Mao
If you look at the point distribution of your cross sections they are quite irregular and have varying number of control points, making a smooth loft unlikely without rebuilding the sections to a similar number and distribution of control points. The cross sections need to match for loft to work properly.
HTH, Jakob
