How to make this solid?
Hi everyboy, I am trying to create a structural pavilion form. Currently i was able to get the stick lines ready and make them iteratble according to required movement. I was aple to generate a stem and an ellipse. The shape and size of these can be changed. Now I want to make them solid. Like shown in the image below. The stem has a thickness of 14x12 inches thick and the ellipse needs to be 12x4 inches thick. The connection between the ellipse and stem should be seamless.
Can anyone help me understand how to make this soild? I have tried sweep 1 but it only sweeps the stem and not the ellipse. I have also tried multipipe but that also gives me pipes and doesnt take exact thickness size into consideration?
You should be able to make it with 3 extrusions:
solidx.3dm (176.8 KB)
how can you show me in grasshopper? This is 3d model only
You should share the file with these simple geometries:
Maybe this! @Tabeer_Tariq (edit 1)
Tabeer Tariq.gh-with Rotaion.gh (45.0 KB) version 2
version 2 :index_pointing_up:
