How to make the planes parallel to the structure?
I want to place the planes parallel to and on top the structure
Grasshopper_Oc.gh (12.1 KB)
Not sure if this is what you want
yes, thank youu
even easier, if done with frames
grafik
Did you use the same commads afterwards?
Nope. I just connected the mid-point parallel vector to the X axis of the plane. Since your curves run along the Y there is no need to feed the Y value of the plane.
Dan is right, but I wanted to keep your way of doing.
I apologize, but after doing as you said, i noticed that it wasn´t quite what i wanted. (in your image it wasn´t clear). I wanted the planes to fill the structure without having those gaps, as you can see in the imagem?
So you want panels, not planes? Like this?
It is achieved by exploding straight lofts, done between each of 23 series of horizontal segments.
3 components if you want individual panels, 2 if you need it in series.
What is the name of this command ?
Flip Matrix
