How can I make solid (Open polysurface to solid) in rhino. Attached my Rhino file.
Concrete.3dm (848.3 KB)
The Size of this object is quite huge… 13~14meters long?
Perhaps you can lower the tolerance of the file itself.
Then explode and join to get both object as closed polysurface then use boolean.
Hi there,
I exploded the object twice, since it was a block already and then used BooleanUnion - Command line says: BooleanUnion failed.
If you do showedges, you can see that
couple of edge are out naked, and out of tolerance.
By going to File->Properties->Units
The tolerance set on the file is in mm and 0.0001units. which seems to be overspec for the size of the object.
I changed model units to meter and set scale pop-up yes.
Explode the part to surface then join all together again and it should close.
same for other part.
Attached is the file after closing surface.
Concrete_meter.3dm (1.6 MB)
Then boolean union.
Thank you for your replies. Still I am getting one error in circular portion.
Can anyone help?
attached Rhino file. Please note I am using Rhino5.Concrete.3dm (1.1 MB)
Yes its offshore wind mill platform. 14m long.
Sorry about the rhino version…
Currently using my phone so can’t convert at the moment.
I guess using matchsrf in the open edge may help, though surface might change a bit.
May need to explode first then join to get all edges connected.
I solved it myself. Thank you for your help.
This technique worked out for my CAD thank you very much Toshiaki !
