How to make selections more visible
HI, I am trying out Rhino8 and have a new Lenovo laptop, with an RTX4070 GPU and a 2560x1600 screen.
I have the problem that the selected objects highlight line is so thin that I can not see it if its selected a line/edge/etc that overlies another objects, eg a rectangle curve over a matching box. If I select the rectangle curve, I struggle to see if its selected. I have changed the colors but that only helps marginally, and I prefer yellow. The problem exists in almost all display modes.
Is there a way to make the selected lines bolder, or some other solution?
OK, found a working solution… under preferences, views, display modes, I set the curve scale to 2, which is the same as the surface edge scale
