Is ist possible to make automatic multiple fillets in/on a curve?
the result should be a curve like this (I mad it by hand and several clicks) with the minimal Radius=X
-Carsten
Does FilletCorners work for you?
Hi, this is helpful, but my path also include “smaller” fillets, which are not corrected, as you can see here in yellow:
If you have an existing fillet already when running FilletCorners, this won’t be changed, the command can’t alter any portions of the curve that are not a sharp intersection.
