What I see in the tutorial and what is shown in my Rhino viewport are different.
In the tutorial, the mesh preview in Rhino will change in real-time as the point(anchor) is moved, but when I do it, I need to move the point to a certain position to see the result.
I wonder how can I make it looks like in the tutorial?
Thanks!
If it is related to the specs of the computer:
Mine is like below:
GPU: RX 580 8G
CPU: Ryzen 3700x 4.4 GHz
32G RAM
Either you change your preview colors clicking the orange / white icon in the upper right corner or you’ll have to add a Custom Preview component with a color swatch or create a material if you need transparency.
In the tutorial video you show they are moving the point with the Grasshopper gumball - this causes live updates of the solver even as the point is being dragged.
You are using the Rhino gumball, which only passes the updated position to grasshopper at the end of the move.
You can see the difference because the Grasshopper gumball only shows the arrows for translation, while the Rhino one also shows arcs for rotation (which isn’t needed for a point).
To use the Grasshopper gumball, the point needs to be set by point not by reference (or internalised, which turns a referenced Rhino point into a Grasshopper editable point).
Make sure the gumball option is switched on in the Grasshopper menu, and select the point component in the Grasshopper window, then the gumball handles show in the Rhino window and your can drag them.
Hi Daniel Piker,
I guess I met the same issue. I turn off the rhinl gumball and only used the grasshopper gumball, however, the passes only updated after the end of the move.
