How to make curves thicker when working
is there a way to make the curves thicker in the viewports while working ?
Thanks
Alex
Hi Alex - you can set curve thickness per display mode-
What Pascal said, and even make new displaymodes (easiest is to duplicate the default ones and edit those)
and assign those with shortcuts like the example here that sets “Shaded” with the shortcut “ds” so I can type ds enter (Or even faster ds spacebar) to automatically set the display mode to shaded.
use _ in front of a command to make Rhino use the english command (in case you use a different language) and use ! first to termintate other commands if desired. (not needed for displaymode change)
thanks a lot
Thanks Holo
