hi, when I use “Insert Block as link ( reference )” it forces me to specify the new location in 3D space. how do I set this to match the original world location?
for instance, a surface is created in another software located at world 10,20,0 (x,y,z)
when I attempt to import in rhino using insert block, I would like to have it sit on rhino world 10,20,0 as well.
Hi pascal, thanks, that does the trick, the only problem now is I cant reference a Block instance with specified name in Grasshopper. Ill try to look for some GH addon to deal with this thanks
Hi SamPage, Worksessions is great but I cant pipeline my Geometry to Grasshopper with worksession
