How to macro the change object layer button?
Talking about this little button.
I can’t work out the command for this?
-_ChangeToCurrentLayer
Thanks for your help, but that command changes the selected object to the active layer.
The button changes the selected object to the highlighted layer. (which is what I want)
Hmmm I can’t find such a command either. Using the ‘ChangeLayer’ command and manually selecting from the list of layers might be a viable option for you?
No I’ve already tried that.
I would really like to bind this button to a keyboard shortcut to decrease the need to pick that little button so often
You can try this script and let me know how it works:
ChangeObjsToHighlightedLayer.py (791 Bytes)
Seems to work perfectly at first glance, thank you !
