How to loft/sweep series of closed profiles along closed loop path?
Hello!
I am looking to make a chain link and sweep a surface across a series of profiles along a path. The path is the center point of those profiles, however I don’t know of any options in Rhino or grasshopper to use these inputs to make a surface/solid. Basically wanted to try making a loop where the two long sides have sharp square edges and the rest of the chainlink is round. I tried moving the path line to the edge (2nd image) and use it as a rail in the sweep command but that did not work. I attached the file below sorry in advance if it is disorganized I come from Solidworks and am very new to all of this. Should I be thinking about this differently?
Thanks!
Jewelry Chain link.gh (57.9 KB)
