How to locally resize generated voxels
I’m a beginner at Grasshopper. I saw a tutorial online about parametric sole design. I want to know if the space where the lattice is placed can be adjusted locally.
I used twistbox consecutive meshes in pufferfish to generate a space grid, and I want to know how I can resize this grid so that the inner grid is smaller and the outer grid is bigger.
Probably something like this?
(its not 2D, but we can adjust it to 3D)
For me, the key is to be able to generate that sequence to divide the surface/mesh with.
If you provide the base geometry that you want to make the lattice on, I can try adjusting the script accordingly. Or maybe you can do it yourself :wink:
lattice 1.gh (14.1 KB)
