Hi all. I have already prepared materials in Rhino. How can I load them in visualarq? As you will see from the screenshot there is an inactive buttons? I use latest version of VA 1.95, but in older releases same problem.
Thanks
Hi Simeon, the Select Material dialog doesn’t let you select materials of some render engines, like the Rhino Render. We are studying how to fix this. As a workaround you can set the styles (and their components) to specific layers, assign the material “By Layer”, and then assign the Rhino materials to the layer where the styles are located.
