How to load a Python custom command in R8?
Hello!
What I’m trying to do is installing a custom command that worked in R7 for R8. For that, I copied the whole folder
C:\Users\xxx\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\PythonPlugins
to
C:\Users\xxx\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\PythonPlugins
because it didn’t exist there yet (strangely, at my home computer, it did after installation).
However, none of the commands are found by R8 after a restart.
So, I’m trying to find out how to create a custom command in R8. In the script editor in R7 there was a template to create a custom command.
I can’t seem to find this in the new script editor in R8.
When I choose “New”, I get this:
What am I missing?
Thanks!
I am not familiar with the way you had your custom commands in Rhino 7. In Rhino 8 however, the designated way would be to create a Rhino Plugin with your Python commands embedded. It is quite straightforward if you can deal with the Newton DLL bug.
Here’s a short tutorial from McNeel: https://www.youtube.com/watch?v=sQwDIHbYB6Q
