How to list yak sources?
Hey Discourse,
Is there a way to list the current sources yak is using to find its packages?
EDIT :
From the yak.exe command line tool*
– cs
  1. Go to Options > Advanced and look for the Rhino.Options.PackageManager.Sources setting.
Sorry I should have specified I meant from the yak.exe command line tool. I’ll update my question.
I’m afraid there’s no way to do it via Yak CLI.
Hi -
I suppose that, as long as you don’t explicitly use a source argument, the only source that is being used is https://yak.rhino3d.com.
A .yak file is just a .zip file…
– Dale
I know, but I’d like to be able to see all the sources currently being used by Yak, or I guess, without opening Rhino
@wim very true. I’ve been trying a lot of experiments with yak and one fantastic thing I’ve found is that if I put different versions of the same package in a different source location, it combines them together in the package manager in Rhino.
I’d just like to be able to get these sources via command line for a tool I’m making.
– cs
