I want to use user text for this but I don’t know how to use it . Like text entity etc. any one can help me with this.. Is there any component to identify it in GH
I just have plan of 2BHK in that I am giving rectangle on this plan so GH will take the text inside of the rectangle automatically . and use the rooms names to export area excels.
Dear @Snehal_Raut. Is this what your are looking for? Or could use as a starter?
link textEW.gh (9.8 KB)
Thank you @Eef_Weenink .. but I am not looking for this.
consider I already have plans and I am making rectangles on it and through that rectangle, it will extract area and also identify text inside of it. and I will export excel. that’s the plan.![]()
Then please upload an example of such a room and the data you want to export.
@Snehal_Raut is this something like what you’re after? It assumes the room shapes and text objects are created in Rhino but then should sort all the data for you. Hope it’s clear enough
I don’t normally work with text objects in grasshopper so maybe there’s a more efficient way to turn them back into strings. Likewise there may be a better way to check if the text is inside depending on your file.
textinsidecurves.gh (13.8 KB)
