How to let user pick a vertex point on a brep?
Hi guys,
I thought it is very simple and straight forward, but I am stuck here. I want to let user pick two vertex point on a brep solid. It may not be that simple. Could anyone please help me how to do that in this case?
I have checked chatgpt, it gives me a complex code, I don’t like it. I think it should a very simple code. Here I have this:
const CRhinoObjRef& objref1 = go1.Object(0);
Now how can I get the point from objref1 which is a vertex point?
Thank you.
John
Hi @smartunfold :
May be you need to do like this.
    CRhinoDoc* doc = context.Document();
	if (nullptr == doc)
		return CRhinoCommand::failure;
	CRhinoGetObject go;
	go.SetCommandPrompt(L"Select Object");
	go.SetGeometryFilter(CRhinoGetObject::surface_object | CRhinoGetObject::polysrf_object | CRhinoObject::extrusion_object);
	go.GetObjects(1, 1);
	if (go.CommandResult() != CRhinoCommand::success)
		return go.CommandResult();
	const ON_Brep* brep = go.Object(0).Brep();
	if(nullptr == brep)
	CRhinoGetPoint gp;
	gp.SetCommandPrompt(L"Pick Point");
	gp.Constrain(*brep);//Lock Point On Brep
	gp.GetPoint();
	if (gp.CommandResult() != CRhinoCommand::success)
		return gp.CommandResult();
	ON_3dPoint origin = gp.Point();
	return CRhinoCommand::success;
…you can do so by custom geometry filter
you have to check the componentindex componentindextype in the filter to see if it is a brep vertex.
https://developer.rhino3d.com/api/rhinocommon/rhino.geometry.componentindextype
not sure if there is a simpler approach.
happy coding - kind regards -tom
thank you. I have changed my codes so I can avoid this issue. Thank you very much.
