How to know if the Windows UI is in darkmode in C++?
I am trying to read if the Windows Rhino UI is set to darkmode with the C++ API.
I did not find anything in RhinoApp().AppSettings().AppearanceSettings() and also did not find a way to read the advanced setting Rhino.Options.Advanced.DarkMode.
How do I know if the user has set Rhino to darkmode?
Thanks for the help,
Daniel
Hi @Daniel_kronos,
https://developer.rhino3d.com/api/rhinocommon/rhino.runtime.hostutils/runningindarkmode
Helpful?
– Dale
Hi @dale,
Thanks you for your reply.
I have also seen this in RhinoCommon. But to my understanding I can not call RhinoCommon code from c++ and I dont have any C# code in my projekt.
Ist there a way in the c++ API?
Regards,
Daniel
Hi @Daniel_kronos,
Yes, use CRhinoUiPaintColorSettings::RunningInDarkMode.
const CRhinoUiPaintColorSettings& settings = RhinoApp().AppSettings().UiPaintColorSettings();
bool bDarkMode = settings.RunningInDarkMode();
– Dale
After updating the SDK, this worked.
Thank you for the quick help!
