When I am modeling for instance a wall, the Properties Menu shows all the relative data of that particular wall which is very helpful. However, the Properties Menu disappears when I execute a different command and then reappears when I select on a particular object. It can get quite distracting and interrupts the modeling workflow because the Properties Menu appears and disappears.
Is it possible to have the Properties Menu to be kept floating in the foreground?
Thanks.
