I am working in Rhino 7. Trying to make a heart following D. Buscaglia’s instructions but I am unable to get a closed curve. Here is my file.
Which curves?
Please post a file or at least a screenshot…
The end points are not coincident, hence your curve is open.
This is your original file:
Heart in progress.3dm (2.3 MB)
Thank you. Then all i need to do is use the move comand?
Yes, pretty much.
Select one of the two control points and move it to the other one.
thank you
solved ?
please check martins post as solution, so others don t need to dig in.
Thank you it was solved. how do I mark it as solved?
