I have a plastic pipe which has a “squarish” shape (not perfectly circular) and I’m trying to infer the exact actual geometry based on the following four (4) measurements:
- Bigger diameter : 39.5 mm
- Smaller diameter: 35.5
- There’s a fillet radius in the “corners” of approx. 2.5 or 3 mm.
- The maximum diagonal diameter is 40.5 mm.
- The radii of the bent sides are not known/measured (but they obviously do not conform to the measured diameters)
Q: Can the “true” geometry (like the exact position of the corner radii, and it follows, the radii of the sides) be exactly calculated based on the above dimensions?
I made a manual approximation based on the above dimensions, but I hope that someone smarter than me can infer a more exact geometry:
//Rolf
