Sure, lets say i have a bunch of somethings called “Positioning Strategy”, and each of them contain a bunch of options users should be able to set; I want those options to be displayed in my Rhino Plugin, but only those belonging to the selected Positioning Strategy. Therefore I created a Combobox
CRhinoUiOptionsListCtrlGroupComboBox m_PositioningStrategy;
and at some point during startup I use my existing options to fill it:
foreach(auto posStrategy, setup->getPositioningStrategies()) {
auto name(posStrategy->getName());
WinFormFromOptionController::addToRhinoGroupCombobox(name,
posStrategy->getOptions(*setup),
m_PositioningStrategy,
m_PositioningStrategy.IndentLevel()
positioningStrategyIndizes.insert(std::pair<ipt::String, int>(name, i));
In WinFormFromOptionController::addToRhinoGroupCombobox
I now add my options to that GroupComboBox
bool ipt::WinFormFromOptionController::addToRhinoGroupCombobox(
const String& name,
SharedPointer<OptionController> oc,
CRhinoUiOptionsListCtrlGroupComboBox& combo,
int indentLevel)
if (!oc) {
return false;
bool translatedAllOptions = true;
ON_SimpleArray<CRhinoUiOptionsListCtrlItem*> items;
// OptionController contains our internal option structure
foreach(auto sibling, oc->getOptionSiblings()) {
CRhinoUiOptionsListCtrlSeparator* sib(new CRhinoUiOptionsListCtrlSeparator(sibling->getId().toStdWString().c_str(), indentLevel + 1));
items.Append(sib);
foreach(auto group, sibling->getOptionGroups()) {
CRhinoUiOptionsListCtrlSeparator* gr(new CRhinoUiOptionsListCtrlSeparator(group->getId().toStdWString().c_str(), indentLevel+2));
items.Append(gr);
foreach(auto option, group->getOptions()) {
auto bo(option.dynamicCast<BooleanOption>());
if (bo) {
CRhinoUiOptionsListCtrlCheckBox* checkBox(new CRhinoUiOptionsListCtrlCheckBox(bo->getId().toStdWString().c_str(), L"Activated", indentLevel + 2));
checkBox->SetCheck(bo->getValue());
checkBox->SetIndentLevel(indentLevel + 2);
setItemStates(checkBox, option);
items.Append(checkBox);
continue;
auto dblo(option.dynamicCast<DoubleOption>());
if (dblo) {
CRhinoUiOptionsListCtrlEditBox* dblEdit(new CRhinoUiOptionsListCtrlEditBox(dblo->getId().toStdWString().c_str()));
dblEdit->SetEditType(CRhinoUiEdit::edit_type::et_double);
dblEdit->SetText(Double(dblo->getValue()).toString().toStdWString().c_str());
dblEdit->SetIndentLevel(indentLevel + 2);
setItemStates(dblEdit, option);
items.Append(dblEdit);
continue;
//.... cast and append all the other option types
// catch having forgotten an option type...
translatedAllOptions = false;
combo.AddGroupItem(name.toStdWString().c_str(), items);
return translatedAllOptions;
Later I want to identify these options in Callbacks such as
void CRhinoUiOptionsListCtrl::OnItemComboBoxSelChanged(CRhinoUiOptionsListCtrlComboBox& item)
or
bool CCalmOptionsControl::OnItemButtonClicked(CRhinoUiOptionsListCtrlCheckBox& item)
Simply put: Is there an elegant way to find out, to which CRhinoUiOptionsListCtrlComboBox
an item like CRhinoUiOptionsListCtrlCheckBox
belongs? The label is not sufficient because I cannot guarantee uniqueness.
