How to hide isocurves by command?
Hi
In the RhinoSettings show surf isocurves = not
I work with t-splines, sometimes I convert it to NURBS
When converted, isocurves appear.
I can not find a command to hide it.
it can only be a tick in the properties of the object.
I would like to write a macro of this kind
! _tsConvertToRhinosurf
_show surf isocurves = not
Please help me do this with a macro
Don’t work with T-Splines, but probably something like:
_Pause
_Selllast
-_Properties _Object
_ShowIsocurves _No _EnterEnd
I assume that you need to choose objects to convert, hence the _Pause after tsConvert. If the objects that are converted to surfaces are already selected after conversion, you might not need the _Sellast.
Thank you very much!
I added one more pause - it works
!_tsConvertToRhinosurf
_Pause
_Pause
_SelLast
_SelNone
Mitch,
Can you tell how to colored an object with a macro?
For example in Red
Properties - Display color - Red?
! _-Properties _Pause _Object _Color _Object 255,0,0 _EnterEnd
Thank you so much friend!
