How to hide edge after joining two geometry together
Hi there,
I would like to remove the edges after the Boolean operation. Is there any quick way? The only solution I have found is to Explode the unified geometry then to use the Merge command to merge the surfaces.
Have you tried the ‘MergeAllFaces’ command on the joined shaped?
Thanks, that is now sorted.
