I have two separate coplanar surfaces/solids in Rhino that touch each other perfectly in the same plane.
In my custom display mode Rhino still shows the edge/seam line between them, but I would like them to appear visually as one continuous surface in the viewport.
Is it possible to hide these intersection/seam edges in Display Mode settings without boolean unioning or merging the objects into one polysurface?
I still want visible outer edges/silhouettes — just not the internal coplanar seam lines.
Hi N+P, This would be a case for make 2d and manual line removal. In the Rhino display environment manually removing/hiding edges, or partial edges in a view isn’t possible.
I’ve added a feature request to see what can be done.
