How to give 3D surfaces a certain thickness
How can I give the attached surface a certain thickness.
I tried to convert in nurbs and extrude or paralell solid.
Did not workout. Sometimes Rhino8 hangs for a long time and sometimes the result seems to be monodirectional in z-axis only.
I would like to have a clean thickness that is the same at any point of the hull.
iwata 300 test.stl (1.7 MB)
iw300 test.3dm (1.5 MB)
This is a mesh, with bad parts:
Converting it to nurbs will mean creating a polysurface with countless triangular faces. Avoid.
Your best option would be to re-trace the U and V isocurves manually and then rebuild your surface in a clean way.
Or, ask whoever generated this geometry to pass you the underlying starting nurbs object.
First step, cleaunp the geometry, it have crumbled parts, self-intersections:
So you say that enhancing thickness does not work because of those errors in the geometry and then things might work out?
I also have a point cloud, generated from an excel worksheet that looks clean, but I have no idea how to make this a surface nor give it a thickness.
From your mesh, you can:
_ExtractWireframe
_SelShortCrv with a threshold of 2 units
_Join , now you have many curves
_Rebuild with 30-ish points and degree 3
_Loft with closed option
iw300 test.3dm (213.6 KB)
Note:
your outer border is partially missing a rows of points, this means the extracted and rebuilt curves have not uniform lengths in some parts, and indeed you can notice a bit of “wobbling” in the longer naked border.
Good luck!
Your thickness is zero, nothing to “enhance”.
And, generally giving a thickness to a mesh will always result in non-constant thickness (but considering the density of the vertices we can probably ignore the error…) OR a huge increase in vertices amount.
For this kind of shape it’s easier to work directly with nurbs, imo.
Your calculated points are better handled by a script, probably, but I see there is some spiral ongoing, not a grid-like structure, and this complicate things.
So the file you modified ssems to be already treated/made the way you described, right?
In that cas I will have to study the way you described and see if I am capable to do this myself on this and the next project.
Thank you so far!
I get to this stage:
Then loft won´t work. Says “Some, but not all, nodes touch each other.”
Solution
LOFT.3dm (943.6 KB)
What I do is the following.
I enter my data in an excel sheet that comes back with a point cloud.
I let chatgpt handle and make an stl out of it.
Now I used your method to create a python script that translates the mesh into curves as pwe my last posting. Then loft fails on me. That is where I am now.
Solved. The erroe had been in the scriptfile
