How to get the thickness data of each mesh point?
Hello,all
After optimizing the shell cross section, how can I get the thickness data of each point on the mesh but not just the view with legend?
Thank you for help.
You can use the DIsassembleCrossSection component to extract all of the thicknesses of your mesh faces.
You will most likely need to use additionally these components: DisassembleModel > Disassemble Element > DisassembleCrosSection to obtain the list.
Thank you for your help Matthew, the problem has been solved.
