Hi All,
How can i find out if any key is pressed in rhino view port and which key pressed by using Rhino.Net / Rscript
Hi All,
Ok,
found the way
Sharing here if any one needs :
Public Declare Function GetKeyPress Lib “user32” Alias “GetAsyncKeyState” (ByVal key As Integer) As Integer
Uder timer Control :
Private Sub tmr1_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles tmr1.Tick
If GetKeyPress(Asc(“W”)) <> 0 Or GetKeyPress(Asc(“w”)) <> 0 Then
msgbox(“W Pressed”)
End If
End Sub
