Hello, I am trying to recreate the [ ExtractForFabrication-Demo.3dm] so that I can create section curves for CNC machine. I label my section and then apply a linear array. The names are not serialized though. For example, if I label the first one as C_00, they all will have that label. Any advice?
Hi Xeon -
I created a clipping plane using the ClippingSections
command and changed the default “SEC” name to “C”. I then used the Array
command to create copies of this clipping plane. That seemed to add the correct suffix to the names:
Are you taking different steps?
AMAZING! Thank you Wim! I was using “ClipplinPlane” to create the sections.
