How to get rid of these artifacts?
Hello Iam trying to model a ducks head.
but I’m having a weird artifacts at the mouth.
what iam i doing wrong?
best regards
DUCK.3dm (2.5 MB)
NGons in Your layout !
Target in SubD is clean quad-layout
do you think its possible to rescue it?
Your file has two overlapping SUBD ducks. Move them apart and it looks fine?
Hey i know That there are two ducks. But this is not the problem. Try to turn ghosted view on to see what I mean and maybe look at the pictures
Thanks
Dear @d.pfifferling as eddi already pointed out - you re using n-gons - faces with more then 4 corners. And you combine them with creases … this will result in the uncontrolled effekt youre getting.
this ist the most problematic face - with 6 corners (n-gon):
(it s still 6 corners - even if 4 line up)
I think you need a few more edges / faces to receive more ore less what you re targeting:
Also try to avoid a starpoint (more then four faces meet at one corner) combined with crease
hope that points in the right direction - kind regards -tom
Thanks Tom,
this is a good help already
I was looking for a guide how to use or setup a model with quads correctly but couldnt find a good one.
this is a good start
thanks
Design should start at least with a sketch
In 3d space even better with sketch of side- and front view
Thus key points are detected before modeling
I have made a little friend
There are triangles and ngon, but hidden :wink:
DUCKx.3dm (737.6 KB)
