How to get Rhino curves exported as AI?
if I select the curves created by Make2D, export them as AI and I open the file at Illustrator than no curves are shown. What did I wrong?
-Micha
One thing I’ve noticed is if the AI you export from Rhino has curves that are bigger than your max artboard size in Illustrator (227in x227in, if I recall), it can cause issues. Also have your curves close to the origin when exporting.
Great, scaling down helped. Thank you very much. :slight_smile:
