Is there a way for a python script to get the raw code from another python script?
Similar to how GhPython.Assemblies.CodeGeneration.GenerateComponentCode works?
The output should be a raw string, newlines will be \n etc.
If you wrap the other script in a function then you can get it using inspect.getsource(my_function)
Thanks!
Just wondering how to use this?
would it be:
component = doc.documentId
inspect.getsource(component.functionName)
I just realised the inspect() is usually used to inspect a module, but what if it was to inspect another component?
After looking at the dir(ZUIPythonComponent ), the solution is really obvious.
code = ghpython_script_component.Code
