How to get or calculate time of reading a file?
Hi all,
How to get or calculate time of read a file in Rhino7?
The file is not only 3dm but also stl、step or x_t…
I need time information to check something.
How can I do?
Best regards,
Vaker
import time
import Rhino
start_time = time.time()
Rhino.RhinoApp.RunScript("_Open \"Y:\\our\\File\\Path\\Here.stp\"", True)
end_time = time.time()
Rhino.RhinoApp.WriteLine("Time to open file:", end_time - start_time)
Hi Nathan,
Thanks for your reply.
My situation is I need monitor all file’s reading time in my plugins environment.
Is there function for getting reading time?
Or can I rewrite some functions of SDK to get that?
Best regards,
Vaker
You can register event handlers with RhinoDoc.BeginOpenDocument Event and RhinoDoc.EndOpenDocument Event assuming you’re using .NET to create your plug-in. If you’re doing C++ I’m sure you can find related functions (I just don’t know them as I use RhinoCommon only).
You’ll have to do the book keeping on times yourself, though.
Hi Nathan,
I find the functions:
CRhinoEventWatcher::OnBeginOpenDocument()
CRhinoEventWatcher::OnEndOpenDocument()
It works.
Thanks for your help.
Best regards,
Vaker
