How to get GUID of the offsetted geometry
I would like to get the ID/GUID of each curve after I offset them from the base curve and apply User Text for each one.
Currently I have this;
thicknessPlus = [1,2,3] //list
count = 1
for thicknes in thicknessPlus:
    layer = rs.OffsetCurve(polyline, [0,0,0], thicknes)
    obj_id = rs.GetObject("Select object")
    rs.SetUserText( layer, str(count), "KM40-4960" )
    count += 1
Any idea?
Hi @onrender,
How about this:
polyline = rs.GetObject()
thickness = [1,2,3]
count = 1
for t in thickness:
    curves = rs.OffsetCurve(polyline, [0,0,0], t)
    if curves:
        for c in curves:
            rs.SetUserText(c, str(count), "KM40-4960")
            count += 1
Hi @dale,
What markup are you using to ger code formatted code text.
// Rolf
Code enclosed in tripple backtick
OK thanks, that looks better.
// Rolf
Thanks Dale,
It works very well, brilliant!
Thanks,
Andras
See Steve’s explanation from way back in 2013 (you can add language specific syntax highlighting as well).
